- Sep 5, 2000
- 9,173
- 6
- 81
Damn! HDD prices are back up again?!
So...i will go with the 2500K per your advice.
As for GPU, is there a favorite between AMD/ATI and Nvidia? Which card would you suggest that I start saving for/looking for deals on?
I'm looking for concrete info so I can piece the rest of the system together within my budget.
MC has the 2500k on sale for $150 on Black Friday. You'd have to go early though since supplies will be limited. Great price though if you can snag one.
You said you already have the monitor, mouse and keyboard.
AMD isn't anywhere near Intel's quad-core performance. Compare: fastest AMD quad vs i5-2500K. It's not wise on your budget to spend on anything less than an i5-2400. If you're concerned about budget, the SSD would be the first thing to drop, you can always add it later. I think a sub-$1000 gaming build is fine without an SSD. It takes such a large chunk of the budget that it's debatable if it's worth it for a gamer, even though it'll make the OS more responsive.
Old should be fine still, but just don't 're-use.' There might be some separation with old paste, but I've heard people just mix it back together and it works just fine.Oh yeah, can I use some AS5 that's like 6/7 months old?
1. I am not sure if I would expect a price drop, but Microcenter usually has a good deal or combo with a mobo for the i5-2500K.1)if I can buy a i5-2500k for $180, should i do it now? Or will it drop soon?
2)Is it imperative I get 1.5V ram or is 1.8V ram better?
oh yeah, no arguments there.![]()
you guys think i can get away with OCing with the stock cooler? or maybe just not OCing and using the stock cooler? also, is there any reason i should wait for ivy bridge? its it gonna be OMG better/coming out anytime soon?
damn, my problem is that i dont live near a microcenter (everywhere around here EXCEPT indiana, go figure). do they ship with those prices?
