Build help
Yosoce
30
A friend of mine has had the misfortune of his computer blowing up and we slapped together this quick build on Newegg:
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
$224.90
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
$149.99
ASUS EN8800GTS/HTDP/640M GeForce 8800GTS GDDR3 PCI Express x16 HDCP Video Card - Retail
$364.99
Rosewill R5601-BK 0.8mm SECC Screw-less Dual 120mm Fans ATX Mid Tower Computer Case - Retail
$54.99
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$79.99
ENERMAX Liberty ELT500AWT ATX12V 500W Power Supply - Retail
$109.99
2 x G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
2 x $84.98
TOTAL: roughly $1100
Its been a while since either of us seriously tracked the latest hardware news so I am sure I could use some help. Any input would be appreciated.
Thanks
Yosoce
PurdueRy
13,837
4
Get the eVGA 8800GTS it is significantly cheaper at newegg right now.
Also replace the Enermax for the Corsair 520HX
Roguestar
6,045
Change the motherboard to the Gigabyte DS3. Power supply looks good. RAM looks good. If you're overclocking (and it is seriously so easy it is almost a crime not to) you'll need an aftermarket cooler. Perhaps save a few $$$ by getting the E6420 instead of the E6600.
Puffnstuff
16,256
4,930
The mb is fine also the evga 8800gts 640 is on sale at newegg w/$30 mir and they have a lifetime warranty. The seagate should be fine. If your friend is going to oc then get a decent hsf with a mounting backplate and install it while the mb is out of the case. If his case has poor air flow get a good hsf anyway just to make sure the cpu stays cool. What about optical drives?
Edited in an attempt to hide my momentary lapse of reading comprehension.:eek:
PurdueRy
13,837
4
Originally posted by: Puffnstuff
The mb is fine however dump the ps for a name brand unit. Also the evga 8800gts 640 is on sale at newegg w/$30 mir and they have a lifetime warranty. The seagate should be fine. If your friend is going to oc then get a decent hsf with a mounting backplate and install it while the mb is out of the case. If his case has poor air flow get a good hsf anyway just to make sure the cpu stays cool. What about optical drives?
His PSU is a name brand unit...maybe not the BEST....but certainly VERY good
Puffnstuff
16,256
4,930
Hell I misread that for some reason in my mind I though he'd picked a rosewill ps, silly me. Yes the enermax, I'm running them duh, is a good unit.
