thedoormat
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
In order of priority, Solidworks/AutoCAD, Accounting softwares, excel/browsing etc
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
<$1400
3. What country YOU will be buying YOUR parts from.
USA
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I prefer an Intel processor, and am biased towards ASUS components, but within reason. If a good case is made for not picking from their offerings, I can listen to reason.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
2x 27" Westinghouse Monitors (HDMI) (1920x1200)
7. IF YOU plan on overclocking or run the system at default speeds.
Some light overclocking, since solidworks performance is heavily reliant on CPU clock speed.
8. What resolution, not monitor size, will you be using?
1920x1200
9. WHEN do you plan to build it?
Around BF. But need all components to be purchased on or before 12/25.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No.
Here is a rough Build that I came up with, but am looking for some fine tuning, and general guidance.
http://pcpartpicker.com/p/wqbqwP
<$1400
USA
1920x1200
No.
