I am currently running:
Zotac GTX 260(Stock)
Intel Quadcore Q9300(Stock)
Asus P5N e-sli Motherboard
Coolermaster 550W PSU
4 GB Kingston memory (Not sure which component, i.e, ddr2/ddr3)
500 GB HDD
I mainly want to improve my computing power with games like Battlefield 3 which bring my system to an extreme lag sometimes with air vehicles with settings turned to Low and Mesh quality at High(I need it for spotting). I run games at 1920x1080 resolution which usually causes the most lag
I am looking to upgrade to a better PC Case as well(buying it separately outside my above budget), so any suggestion is appreciated(the current one doesn't hold well at higher temp during summer and has only 1 back fan support)
My Budget for the summer is 400$ CAD
I am unfamiliar with current PC parts specs so I don't know whats the best with my budget and I'd like to start getting into customizing my PC on my own(never done it before), my current PC was bought as is from a friend of mine back in 2008
Thanks for reading, any suggestion/ideas is appreciated
Edit: Extra info, I live in Toronto, Canada so I'd like to save on shipping if it makes any difference
500 GB HDD
