Build help needed.....
Skrigg
4
I heard you all were pretty awesome for helping people and their builds so I thought I'd give this a shot. So without further ado.
1. What YOUR PC will be used for. 99% Gaming.
2. What YOUR budget is. $1100
3. What country USA
4. IF YOU have a brand preference. Intel, EVGA Nvidia
5. Current parts used: Case, mouse, Keyboard, Monitor. Optical drive. I have an OS as well.
7. I plan on overclocking, Air only.
8. What resolution YOU plan on gaming with. 1920x1200
9. WHEN do you plan to build it? Has to be in the next week to 2 weeks.
Ok so I'm currently gaming on a 4yr old system, c2d e6300, 8800gtx. and it just bit the dust. I was going to hold off for a SB build but I can't deal with 2+ months of downtime. So what am looking for is a build that would perform as close to a SB as possible for gaming. This is what I have come up with, the only thing that I am 100% sure I want is the EVGA GTX 570. If I could get a 2500k and a P8P67 Pro somewhere I would do it, but I don't know if that is possible.
CPU - I7 950 - http://www.newegg.com/Product/Produc...82E16819115211
MOBO - Asus Sabertooth X58 http://www.newegg.com/Product/Produc...82E16813131665
Memory - Gskill Ripjaws http://www.newegg.com/Product/Produc...82E16820231277
GPU - EVGA GTX 570 http://www.newegg.com/Product/Produc...-593-_-Product
PSU - XFX 750w http://www.newegg.com/Product/Produc...82E16817207003
HS/F Hyper 212 - http://www.newegg.com/Product/Produc...82E16835103065
HD - Samsung F3 - http://www.newegg.com/Product/Produc...82E16822152185
Cost with shipping $1,112.45
Im just now playing catch up with current tech, for gaming how much of a downgrade is the 950 from the 2500k? What kind of longevity can I expect in relation to it becoming a bottleneck for future GPU's? Anything on my list stick out as just plain overkill or a bad choice? Thank you for your help.
BoomerD
66,714
15,116
While the components you've chosen are VERY good, you will take a sizeable hit in performance with the i7-950 over the i5-2500K:
http://www.anandtech.com/bench/Product/100?vs=288
If you can wait for the re-release, you'll get far more "bang for your buck."
Even the i5-760, while a bit slower than the i7-950, is still more "bang for the buck" when comparing the costs of the two processors and boards. Yes, the i7-950 is faster in just about every category, but at a significantly higher price.
The Sandy Bridge processors and boards are still available through some outlets, although it looks like supply & demand may be driving the price above normal retail.
http://www.google.com/search?hl=&q=...N&tab=wf&biw=1250&bih=755&fp=3652203fe9ed933e
http://www.google.com/search?hl=&q=...&aq=f&aqi=&aql=&oq=&pbx=1&fp=3652203fe9ed933e
Skrigg
4
The i7 950 is a terrible choice for a gaming rig. It just costs way too much for what it does. Get the i5 760 and GA-P55-USB3 and spend the difference (~$150) on a GTX 580 or SSD.
The rest of the build looks good though.
I tend to keep video cards for a fairly long time, is there any chance of a bottleneck situation between i5760 and current gen video cards?
BoomerD
66,714
15,116
I have an EVGA 460GTX with my i5-760...I'm happy as hell with it. I'm sure the 570 would be even better.
wuliheron
3,536
Yeah, the i5 760 is a better bang for yer buck. That's also a nice power supply, but unless you have a small case that is bad for wire management you can easily get by with something cheaper like a corsair tx750. Likewise the mobo with 16x16 is overkill and at most will improve frame rates 2-3%. With the savings you could get from all 3 you could easily afford a better gpu, an SSD, or whatever.
Personally, if I intended on keeping my computer as long as you kept your last one and on spending that much on high end components I'd just wait for sandy bridge.
