Hi all, I have recently decided (due to some suggestions made in a previous thread by lakedude) to build or buy a good raid NAS. What I am looking for is drive redundancy and high capacity storage. I am open to building a system and using something like FreeNAS, or something similar. i am also open to buying a stand alone unit (that is upgradeable) from dell or other retailers.
Price range is $2000.00
Hit me with your suggestions!
For details:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
-STORAGE, NAS/RAID
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$2000.00
3. What country YOU will be buying YOUR parts from.
USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
N/A
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Nope
7. IF YOU plan on overclocking or run the system at default speeds.
Default
8. What resolution, not monitor size, will you be using?
Irrelevant, no dedicated monitor necessary
9. WHEN do you plan to build it?
within the next 2 weeks (before Jan 1st 2016)
For details:
-STORAGE, NAS/RAID
$2000.00
USA
N/A
No preference
Nope
Default
