Hey
The build I refer to is in this thread, posted by jchu14 (not the OP).
http://forums.anandtech.com/showthread.php?t=2093609&highlight=700
I am trying to match it but combos have changed.
I found the same CPU + PSU combo:
http://www.newegg.com/Product/ComboD...t=Combo.468987
But no luck with the others. Can anyone (including jchu14) advise
how to approach this? Only difference is 1GB GTX460 instead of 768MB
(unless it can't be done under $700).
Thanks ^_^
Thanks ^_^
