imported_scottw
Hey all, new to these great forums and looking for opinions.
1 - What will yor PC be used for:
This particular PC will be used strictly for gaming. I have others for the boring stuff. The games I play most are WOW, EVE-Online, Bioshock, COD4 and TF2. Im sure that will change as time moves on.
2. What YOUR budget is:
I am shooting for 1000-1500 though I already posess many of the items I need. I prefer to build a "good" PC every 2 years than a "uber" one every 3-4. So I try to keep costs down when building since I build often.
3. What country YOU will be buying YOUR parts from:
Im in the US and will be buying parts from the US, neweggg specifically.
4. IF YOU have a brand preference:
Im not a fanboy but feel most comfortable with the standard Intel-Nvidia combo for CPU/GPU. Motherboards are either Gigabyte or Abit. Ram is corsair or mushkin and for harddrives I lean towards Western Digital and Maxtor. I have a power supply phobia and pretty much relly exclusively on PCPower n cooling.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are:
Yes I will be reusing some parts. I will be transfering a copy of Windows XP, sound card and the optical drives. I already purchased a Cooler Master Stacker case and Rapotr SATA Harddrive. Everything else I need to purchase.
6. IF YOU have searched and/or read similar threads:
Yes I read these type forums on several sites everyday. I am fairly well versed in the current state of things but am no expert. I see threads with builds close to mine virtually everyday but each is unique and I wanted to be avsolutely sure before ordering.
7. IF YOU plan on overclocking or run the system at default speeds:
Because I builld every 20-24 months and move the old PC on to other duties I try to extend the life of them as long as possible and keep the build as simple as possible to minimize problems. Im not rich but money isnt really an issue either so paying a premium isnt a problem. Therefore I will not be overclocking this particular PC.
So with all that done ehre is what I intend to buy. If you see any hardware conflicts, problems or suggestion please let me know. Otherwise id appreciate as many "seal of approvals" as I can get. I will be ordering Tuesday of this week and building 1 week from today.
Power Supply: PC Power & Cooling Silencer 610
Motherboard: Gigabyte P35-DS3L
Processor: Core2 6850 3Ghz
Videocard: EVGA 8800GT 512MB
Memory:2 x 1G Corsair 1066 PC8500 Exact memory listed on the Gigabyte "Supported memory" list from their website. But the more I read the more I am starting to think this memory is a BAD choice? I see alot of people compaining of hardware failures after 4-6 months and that it does not run at the specified speeds. I felt good becuase it was on gigabytes "support" list but please talk me out fo it.
Alread have:
Case - Coolermaster Stacker
Soundcard - SoundBlaster
OS - Windows XP
Optical Drives - Liteon DVD/CD Burner
Hard Drive - Raptor SATA
Other Notes:
1 - I have no interest in SLI for this build.
2 - 90% of play time is split between WOW and EVE which are not graphically demanding by todays standards so I dont have a need for the GTS.
3 - Paramount is stability with performance a close second.
4 - I know its a bad time to build but my backup PC just died and my hand is being forced(who can live with just one desktop 🙂 )
5 - I was considering a Quad core but the extra cost and lack of gaming support at the moment swayed my towards the dual core. I am patient and can build a quad next time, maybe even an 8 core by then 🙂
QUESTIONS:
1 - The motherboard runs up to 1066, the ram runs at 1066 but the proc runs at 1333. Is that a problem and/or will it require anythign special other than plug and play?
2 - Does this motherboard have native SATA support? By that I mean can I plug a SATA drive in and it will recognize it for installing the OS without any special steps? I had an Abit board that did that and later a Biostar that did not and the Biostar was a pita to get working right. If it doesnt have native SATA support can anyone recommend a good(fast) IDE harddrive? Nothing over 120gb as only thing on it will be games.
3 - I see alot of people recommending 800mhz ram instead of 1066. Why is that other than cost? Wouldnt it be betetr to match frequencies of the mobo and ram? I checked and the difference between 2gb of 800 vs 1066 was only about $25-$40. If im willing to pay the premium isnt the 1066 technically "better" for me?
Thank you very much for any input and giving someone with just one post time out of your day 🙂
Scott
Alread have:
OS - Windows XP
Other Notes:
QUESTIONS:
Scott
