RyanGreener
This is a build meant for AutoCAD/Pro Engineer. Basically, a workstation. I don't want a workstation GPU though, those are way too expensive IMO. Anyways, here it is.
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard
MSI R5770-PM2D1G-OC Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR CMPSU-550VX 550W ATX12V V2.2 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power
AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W Quad-Core Processor Model ADX620WFGIBOX
OCZ Gold Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Dual Channel Kit Desktop Memory Model OCZ3G10664GK
HITACHI Deskstar P7K500 HDP725050GLA360 (0A35415) 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
All from NewEgg. Total is ~579 bucks without shipping/taxes. I have a case/optical drive/software/peripherals. All I need to do is decide on a monitor. Also, what PSU is suitable for this build without being overkill? I know Corsair is a good PSU company and I'm stuck between all the variants of it. I chose 550W and hoped that after asking here, I could make the build cheaper. Also, what monitor do you guys recommend? Budget is 200 bucks for the monitor.
Thanks everyone.
Thanks everyone.
