Build for computational research
greenbanana
Hi guys, I need some advice on a build that I will use for computational research and development (mainly in R/Matlab/C/C++/Java).
I currently use a HP Pavilion dv6 with an Intel Core i5 430M with 8GB memory which has worked decently in general but I'm starting to do alot more research and need more computing power. (I typically use my college computers for the heavier tasks but I'd prefer to be able to do all that at home). Also my current laptop is annoyingly heavy when I travel on flights when everything in my carry on really adds up and feel like a bomb, so I'm thinking of getting a mini-ITX (or maybe even a micro ATX) to meet all my computation needs and get an ultrabook/MacBook Air for everything else.
I've been reading a bit about builds and stuff, but generally what I've come across seem to have a focus on heavy gaming and graphics and consequentially the cooling needs for a given system, so I'm still not sure about what kind of hardware I should be looking at for my needs and would like to see if anyone can give me some advice? I don't need any serious graphics at all and I can do with a single HDD, so for these two aspects I'm pretty sure I can fit what I need into an ITX.
My main question is: I'm willing to go all out for the processor and I'd like to know how much overclocking I can afford to do with the amount of cooling I can get in an ITX case (or if an ITX is a good idea for this?)
Thanks in advance!
Do you live near a Microcenter? They have big discounts on Intel CPUs.
If you don't game at all, then you don't need a GPU at all. An i5 Ivy Bridge desktop CPU wipes the floor over its Ivy Bridge laptop brothers. So, even an i5-3570K will be miles faster than your older generation laptop i5.
CPU: i5-3570K or i7-3770K
Motherboard: Z77 mITX board.
Asus P8Z77-I Deluxe or ASRock Z77E-ITX
RAM: 8 GB 1600 Mhz
Storage: SSD is lighter. Whether you need an spinning magnetic drive depends on how much space you use.
PSU: Form factor will matter. Regular sized PSUs will not fit. Some cases come with PSUs
Case: A mini-ITX case
Optical drive, OS, monitor, get them if you need them.
It might be possible to mount one of those big aftermarket coolers depending on the motherboard and case dimensions.
