Build for brother
Jun 14, 2003
10,442
My bro wants to build himself a new computer for uni (now i already explained to him the merits of laptops and the dell out let, but he's quite set on this so im gonna see what i can come up with for his budget)
he also wants to take it to LAN's
now i've done builds before, so im no stranger, however his budget is tight at £500
with this in mind, i think ill be sourcing a lot of things second hand.
i've been out the loop a while though and would like some advice on what are good motherboard chipsets...theres just so many and i have no idea which is best.
following Blains little thread
PC USE: gaming mostly, WoW, Guild Wars, LoTR .. gash like that also taking to LAN's
BUDGET: £500
COUNTRY: UK
FANBOYISM: None really, what evers the best value
OVERCLOCKING: not if i can help it, i will do it, i know how to do it but if/when it al goes wrong a few weeks/months down the line, i wont be there to sort it out so i'd go for reliability.
WHEN: NOW!
rough outline of my plan:
CPU:
tied to the mobo choice, and i really dont know whats good there. Dual core is the choice though and will consider 2nd hand parts here.
MOBO:
not a clue! will consider 2nd hand parts....
RAM:
Already has 2GB of DDR2 ready to go.
GRAPHICS:
with the games he plays and the fact that any monitor he does get will be small.... im suggesting we go for a second hand Radeon X1900XT or similar from Ebay. they can be had for very cheap! and i know they play alot of games very well at 1280x1024
HDD/CD/DVD:
will probably be new, HDD are cheap these days. same with optical drives
SOUND:
On board, but may pinch an Audigy out of an existing computer as it wont need it and it basically already has Audigy level creative on board sound
CASE:
not sure, its gotta be something light, im going for new on this too (less i can find an Antec LanBoy) the new Sonata 3 is reasonably priced and comes with a nice 500W PSU.
PSU: preferably comes with the case so long as its a good make. not the component to cheap out on. looking around 500W mark with Antec, Enermax or seasonic.
OS: XP Pro
MONITOR: probably going used on this too, 17-19inch is realistic limit, WS would be nice...im hunting on ebay.
all in all thats a big ask for 500 quid....im not sure it can be done myself! but perhaps getting lucky on a few deals or auctions and it could happen.
akhilles
336
Eh, 500 quids can buy a new gaming rig. Don't have to go 2nd-hand.
E7200
GA-EP45-DS3R or P5Q PRO
HD4850
320-750GB SATAII HDD (750GB is the sweetspot in terms of price per gig)
Sonata III
Pick out the rest. If you want to overclock the cpu, look into Xigmatek HDT-S1283, Infinity, Ninja, Typhoon, Tuniq, TRUE, etc. And yes, the 500W psu in Sonata III is enough for HD4850 and even HD4870:
http://www.antec.com/us/productDetails.php?ProdID=15137
http://ati.amd.com/products/ra...4800/requirements.html
Jun 14, 2003
10,442
well 500 is absolute max, any savings that can be made, will be so i think im gonna stick by the 2nd hand parts.
i thought about spending a little more on the GPU, its gonna be the most expensive part probably so getting one thats got a lot of life in it makes sense.... 4850 is a great card, so ill look into it.
