Build for a buddy. ~$1200
JustAnAverageGuy
9,057
Build will be mostly used for hobby-level video / photo work. Some gaming on the side.
Trying to keep it under the $1200 mark. Max $1500. Cheaper is obviously better though.
Parts in USA.
Not a brand fanboy.
Will be reusing peripherals - mouse/monitor/keyboard/speakers/etc.
Extra hard drive from other computer may be coming for the ride as well.
Already have an OS. (Win7 Pro 64-bit)
Gone through a few other threads with similar criteria.
Will be doing some mild overclocking. Nothing hardcore though.
Monitors are currently 1600x1200. Planning on updating to 1920x1200 later.
Probably purchase towards the end of August / early September
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Bring on the pain.
Other:
Quiet/noise is a main concern.
No interest in SLI/xfire.
Comes in for a total of ~$1150 shipped.
My main concerns:
Case - Have a little bit of a budget to work with. Anything better noise wise? Possibly a Fractal Design Define R3?
SSD - Would prefer to stay with Intel / Crucial. I've had bad experiences with OCZ drives. Seen quite a few good deals with Kingston V+ drives recently though (96GB for $99). Worth it to look into?
Vid card - MSI's 6870 tends to review pretty well (Noise-wise) and I've had good luck with them in the past. Seems like their 6870 is taking some time to fall in line price wise with the other brands though? Maybe it'll drop closer to buy time
mnewsham
14,539
428
looks fine to me, maybe bump the GPU up a bit as you have the funds. Add some more RAM if needed for the video/photo work. And if it is "real" video/photo work (by real i mean it makes you money and time = money) then possibly bump up to the i7-2600K
T_Yamamoto
15,007
795
i would go with 16 gb of ram, two sticks of 8 gb ram (can upgrade to 32 gb later if you wanted too)
mfenn
22,400
www.mfenn.com
Overall, the build looks good to me.
My main concerns:
The Three Hundred is a very good basic case. The R3 is better/quieter. If noise is a big concern, I would go with it. Otherwise, stay put.
The Kingston drives are really cheap for a reason. Namely, they're not that good.
If your buddy is a big Adobe CS5 user, I'd suggest an Nvidia card like the GTX 560 or GTX 570 though (for CUDA).
