Build for 3 monitors and 2 virtual machines
Discussion in 'General Hardware' started by fgkrew, Dec 13, 2012.
  1. fgkrew
    fgkrew Junior Member
    Dec 13, 2012
    14
    Hello,
    first of all let me tell you that English i snot my first language. im from portugal so the prices here are almost the same but in euro.
    I need to buy a new computer for 3 monitors and the ability to run 2 virtual machines and heavy browsing (20+ tabs) simultaneously. I don´t Play games.
    I would like to have 16gb of ram and an ssd. i will also be making overclock if its needed. i was thinking of spending around 500usd/euro, but i have more available if its really needed.
    Let me know what you think its best for my needs.
    Thanks
  2. Loading...
    Similar Threads - Build monitors virtual Forum Date
    Planning on building triple or quadruple 19" surplus monitor setup General Hardware Saturday at 6:03 PM
    Looking for a triple monitor gaming build! General Hardware Jun 3, 2015
    $1,000 Gaming Build w/Monitor,Mouse,Keyboard. Critique appreciated. General Hardware Apr 29, 2015
    Financial Trading 4-8 Monitor Build General Hardware Nov 18, 2014
    Nu build PC, New HD Monitor for Video-Editing,Photoshop?? General Hardware Mar 4, 2014
  3. dmoney1980
    dmoney1980 Platinum Member
    Jan 17, 2008
    2,367
    9
    what websites would you order from?
  4. fgkrew
    Dec 13, 2012
    14
  5. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    Do you need an OS license included in that budget?
  6. fgkrew
    Dec 13, 2012
    14
    No, i have an msdn win 7 pro license.
  7. fgkrew
    Dec 13, 2012
    14
    i also need advice on buying 2 21.5" lcd screen. i was thinking on spending around 100eur on each.
    i have 3 options around those prices:
    Samsung SyncMaster S22A100N
    LG E2242C-BN
    AOC E2250SWNK
    I already have an acer x233h so these would go one on each side to run one vm each.
    So the total budget would be 700euros.
  8. KentState
    KentState Diamond Member
    Oct 19, 2001
    7,142
    34
    What software will you be running in the VMs? Depending on what you are doing, this could be a very cheap purchase.
  9. fgkrew
    Dec 13, 2012
    14
    The Vms will for testing various operating systems, nothing heavy really.
    Im also very unorganized and always have lots of tabs opened and i want to change between them quickly while running the VMs and maybe watch an video or streaming from the internet at the same time.
    The most heavy program i use its really matlab, and some pcb design programs.
    Since im studying electronics Engineering i would like to be able to use any program that i may need in the future.
    Sorry if the English is not the best :), please make the questions needed.
  10. fgkrew
    Dec 13, 2012
    14
    Can someone please give me some hints on what to buy, i would really like to have for christmas :p
  11. dmoney1980
    Jan 17, 2008
    2,367
    9
    edit: confirmed that h77 and z77 boards and ivy bridge does support up to 3 displays
    here's what I found so far
    Motherboard 90 euro http://www.pixmania.com/pt/pt/12666077/art/asrock/z77-pro4-m-socket-1155-ch.html
    CPU 211 euro http://www.pixmania.com/pt/pt/11764446/art/intel/core-i5-ivy-bridge-3570k.html
    (best i5 available, can be overclocked)
    CPU cooler (helps with noise and overclocking) 29 euro http://www.pixmania.com/pt/pt/11643609/art/cooler-master/ventoinha-radiador-hyper.html
    RAM 69 euro http://www.pixmania.com/pt/pt/12684117/art/kingston/memoria-pc-hyperx-blu-2-x.html#pix-review
    128GB solid state drive 99 euro http://www.pixmania.com/pt/pt/9760816/art/crucial/ssd-interno-m4-2-5-128-gb.html
    do you need a case? hard drives?
    #10 dmoney1980, Dec 14, 2012
  12. paperwastage
    paperwastage Golden Member
    May 25, 2010
    1,849
    not all h77/z77 boards will support 3 display... they can if certain conditions are met*
    *2 displayports plus 1 other port
    the board you chose doesn't (read the manual, page 10, Caution 6)
    http://www.asrock.com/mb/Intel/Z77 Pro4-M/?cat=Manual
    Code:
     You can choose to use two of the three monitors only. D-Sub, DVI-D and
      HDMI monitors cannot be enabled at the same time. Besides, with the
      DVI-to-HDMI adapter, the DVI-D port can support the same features as
    the HDMI port.
    multi-tab browsing is easy if you use the right browser... I open multiple tabs in Opera regularly (RSS reader at end of day), went up to 300 before hitting 4GB limit for 32bit applications
    Virtual Machines: Best for each machine to have a separate disk.... my VMs and Steam would complain a lot(both on same 1TB WD Black drive) if I open them at the same time (takes a long time, HDD cage rattles
    #11 paperwastage, Dec 14, 2012
  13. dmoney1980
    Jan 17, 2008
    2,367
    9
    Good catch!
  14. fgkrew
    Dec 13, 2012
    14
    Thanks for all opinions.
    i was thinking about putting an amd a10 and put another cheap graphic card.
    that way i could have 3 monitors right?
    i think an i5 is a little overkill for what i need no?
    Im reallly used to chrome, and didnt want to change it.
    Please give me a config, even if the item does not exist on the shop i gave you, since i can order from somewhere else.
    So with 500usd what would you buy for my needs?
    cheers
  15. mfenn
    Jan 17, 2010
    22,403
  16. fgkrew
    Dec 13, 2012
    14
    Thanks a lot mfenn :)
    I was thinking about overclocking, and i can spend a few more euros, what would you recommend? i5 3470k?
    And should i change the the mb?
    I already have a 2tb external so i dont need one.
    And what about the lcd?
    LG E2242C-BN
    AOC E2250SWNK
    Any big difference between them?
  17. mfenn
    Jan 17, 2010
    22,403
    If you want to overclock, you will be spending at minimum about 80 euro more:
    i5 3570K 202e
    ASRock Z77 Pro3 90e
    Hyper 212 EVO 32e
    As for the monitor, they are all your standard cheap 1080p LED-backlit TN panels. Get whichever costs less.
  18. fgkrew
    Dec 13, 2012
    14
    OK thanks. its almost done :)
    Just to sure, will i be able to connect 3 monitores without any issues?
    cheers
  19. fgkrew
    Dec 13, 2012
    14
    I can get a used i7 2600k used for 10euros cheaper then the i5 3570k.
    Which one should i buy?
  20. fgkrew
    Dec 13, 2012
    14
    Any help?
  21. KentState
    Oct 19, 2001
    7,142
    34
    For that little money, I'd go new.
  22. T_Yamamoto
    T_Yamamoto Lifer
    Jul 6, 2011
    13,860
    9
    I would get the 2600 at that price.
  23. fgkrew
    Dec 13, 2012
    14
    I was also thinking about going with the i5 but since im overclocking and i read everywhere that the sandy bridge runs cooler and is also a good overclocker i dont know what to choose.
    Also maybe now its not needed but in a year or so the hyperthreading of the 2600k maybe useful....
  24. fgkrew
    Dec 13, 2012
    14
    I already bought the ASRock Z77 Pro4 for the same price of the pro3, so the motherboard is already chosen :)
  25. mfenn
    Jan 17, 2010
    22,403
    Yes, 2 to the 5450, 1 to the IGP.
    I would not buy a used overclockable CPU unless I had complete faith in the original owner. Otherwise you don't know what kind of insane voltages it's been subjected to.
  26. fgkrew
    Dec 13, 2012
    14
    Yes, i was thinking the same.
    Do you think that the power supply will be enough if i oc the cpu?
    Thanks
