Build advice for noob dad please
Status
Not open for further replies.
brian23mj
Hello Everyone,
Looking for some feedback on whether or not this is a good build. Its our first gaming PC and we will be playing all the latest games, fortnite, rainbow six siege, etc. Please help if you have time. Thanks!
$2,462.00 x 1 $2,462.00
Gamer Infinity XLC (NO MONITOR)
https://www.cyberpowerpc.com/system/Gamer-Infinity-XLC
*BASE_PRICE: [+2069]
BLKFRISALE1: CyberPowerPC AULA Explosive 50mm Drive Analog Gaming Headset [White & Orange] [+5]
BLKFRISALE2: 6-FT HDMI Flat Cable, V1.4, Supports 3D & 4K Resolution, Gold Plated Connector Cable [+5] (2 pieces [+5])
BLUETOOTH: None
CABLE: None
CARE1: Cooler Master Mastergel Maker CPU-Thermal Compound Optimized for Thermal Dissipation [+10]
CAS: LIAN LI PC-O11 Dynamic ATX Mid-Tower Dual chamber Gaming Case w/ USB 3.1 Type-C, Tempered glass on the front & side (Black Color)
CASUPGRADE: RGB Multi-Color 16 Million color LED 3x Interior light Strip (top, side, bottom) w/ RF Controller [+29]
CC: None
CD: None
CD2: None
COOLANT: None
CPU: Intel(R) Core™ Processor i7-8086K Limited Edition 4.00GHz [Turbo 5.0GHz] 12MB Intel Smart Cache LGA1151 (Coffee Lake)
CS_FAN: Default case fans
ENGRAVING: None
EVGA_POWER: None
FA_HDD: None
FAN: CyberpowerPC Asetek 550LC 120mm Liquid Cooling CPU Cooler (Single Standard 120MM Fan)
FLASHMEDIA: None
FREEBIE_MN: None
FREEBIE_WAP: None
HDD: 240GB WD Green SSD + 2TB SATA III Hard Drive Combo (Combo Drive)
HDD2: None
HEADSET: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: CYBERPOWERPC Skorpion K2 RGB Mechanical Gaming Keyboard [+73]
MEMORY: 16GB (8GBx2) DDR4/3000MHz Dual Channel Memory (ADATA XPG Z1)
MONITOR: None
MOPAD: None
MOTHERBOARD: ASUS PRIME Z370-P ATX w/ USB 3.1, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe [Intel Optane Ready]
MOUSE: CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition)
OVERCLOCK: Pro OC (Performance Overclock 10% or more) [+19]
POWERSUPPLY: 1,000 Watts - Corsair RMx RM1000X 80 PLUS Gold certified Fully Modular Ultra Quiet Power Supply [+129]
PRO_WIRING: Professional Wiring + [Black/Red] Phanteks Premium Extension Cables sleeved set [24Pin MB + 8Pin CPU + 6+2 Pin VGA] [+39]
PROJECTOR: None
RUSH: Standard processing time: ship within 12 to 15 Business Days
SERVICE: 3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME TECHNICAL SUPPORT)
SLI_BRIDGE: None
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
USBHD: None
USBX: None
VIDEO: GeForce(R) GTX 1080 Ti 11GB GDDR5X (Pascal)[VR Ready] (Single Card)
VIVE_HEADSET: None
WARRANTY: STANDARD WARRANTY: 1 Year Parts WARRANTY
WNC: TP-LINK Archer T9E AC1900 Wireless Dual Band PCI Express Card [+79]
WTV: None
_PRICE: (+2462)
Well, that's more or less an ultimate gaming PC - for now. You could go with a single bigger SSD, but it's not a big deal.
However, new video cards are likely to be available in about three months.
Did you save any money for a monitor? What kind do you plan to get? I suggest 1440p and 144Hz. G-sync too if you're going all out.
No cross-posting of identical threads, across multiple forums.
esquared
Anandtech Forum Director
Status
