1. used for. - Mainly gaming / schoolwork / Photoshop
2. budget . - Around $900. Really don't want to enter $1000 territory
3. country . - USA, newegg
4. brand preference. - Intel / Nvidia
5. current parts - Using current PSU , DVD drives, HDDs
OC'ing later on for a performance boost, probably not when I first buy it..
8. What resolution - 1920x1200
9. WHEN - Soon, hopefully
Case ( $100 )
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
CPU + Cooling combo ( $244 )
i5 2500K / Hyper 212
http://www.newegg.com/Product/ComboD...t=Combo.584425
Mobo ( $153 )
ASRock P67 Extreme4 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
RAM ( $110 )
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
GPU ( $280 )
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
Total: $886
My current GPU (GTX 260 :S) just gave out so I need to buy a new one, and the rest of my computer is circa ~2005 so I figured it's time for a new rig. I've read about problems with the ASUS / Gigabyte P67 boards so I opted for the ASRock which seems fine, also it can SLI if I ever wanted to down the road. The i5 / 212 combo seems highly recommended so I also picked that one.
As for GPU, I'm seeing a lot of people saying a 460 doesn't have enough power for high quality+res gaming so I decided on the 560 Ti which fits into my price range. My budget is met just wondering if there are other parts I should pick instead.
I'm also hearing things about problems with SATA / Sandy Bridge processors so should I wait? I heard it won't be fully fixed until April and waiting that long would kinda suck. Should I just buy the GPU and wait on the rest?
Thanks!
Case ( $100 )
Mobo ( $153 )
RAM ( $110 )
GPU ( $280 )
Total: $886
Thanks!
