- Dec 9, 2009
- 41
- 0
- 66
Hey guys,
I'm going to copy in the requested questions and i'll post below that what i'm thinking of getting and i'd LOVE any advice you can give!
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Primarily to run Vectorworks spotlight 2010 (CAD program with high res 3d renderings).
I also do Game though I haven't done as much as I used to.. FPSers and stuff I play on xbox360 now when I do play.. but still play occasionally.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
2400-2700 not including monitor mouse software or keyboard (only internal hardware)
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I have experience with both AMD and Intel, but I am a nVidia fan more specifically EVGA.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Keyboard, Mouse, Monitor (for now, i'll upgrade to a 30" soon enough so want to be able to push a 30" at full res with no problems).
6. IF YOU have searched and/or read similar threads.
I have, and I see some ideas. I'll do my breakdown off of those.
7. IF YOU plan on overclocking or run the system at default speeds.
Would probably run pretty default. I have limited experience overclocking.
8. What resolution YOU plan on gaming with.
Eventually it would be 2560X1600
9. WHEN do you plan to build it?
next two weeks.
Here's what I've seen so far that I like. I'm going to use newegg.com as reference since I see most people here do as well and i'm a long time buyer of theirs.
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail - $299.99
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Intel Core i7-920 Bloomfield 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail - $288.99
Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145235
CORSAIR XMS3 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model HX3X12G1600C9 G - Retail - $339.99
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167024
Intel X25-M Mainstream SSDSA2M160G2R5 2.5" 160GB SATA II MLC Internal Solid state disk (SSD) - Retail - 549.00
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130526
EVGA 01G-P3-1190-TR GeForce GTX 285 Classified 1GB 512-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail - $399.99
DVD Burner/blu-ray player
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136162
LG Black 8X BD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal Combo LG Blu-ray Reader & 16X LightScribe DVD±R DVD Burner - Retail
$119.99
Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188
Rosewill BRONZE series RBR1000-M 1000W Continuous@40°C, 80Plus Bronze Certified,Modular Cable Design,ATX12V v2.3/ EPS12V,SLI Ready,CrossFire Ready,Active PFC"Compatible with Core i7, i5" Power Supply - Retail - $149.99
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail - $159.99
CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106102
Thermaltake V1 Max-Performance CPU Cooler with Massive 110mm Blue LED Full-Range Variable Speed Fan CL-P0401 - Retail - $61.99
Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Arctic Silver 5 Thermal Compound - OEM - $6.99
Subtotal: $2,376.91
Tax (ugh..CA.. I should ship it to someone out of state and have them ship it to me..prolly cost just as much though) $196.10
Shipping: 26.52
Total: 2599.53
Let me know what you guys think! Anyplace you think i'm overkilling it? Dont have enough? Budget constraints aren't terrible but i'd like to stick somewhere around this price (or lower always! haha).
Thanks, I really do appreciate all the help you guys are to everyone!
USA
next two weeks.
Mobo
CPU
Memory
Hard Drive
Video Card
$119.99
Power Supply
Case
CPU Cooler
Thermal Compound
Subtotal: $2,376.91
Shipping: 26.52
Total: 2599.53
