cbn
I'd rather have a cheap CPU and dedicated GPU than an APU for gaming. Just my $.02 adjusted for inflation
In general, I would definitely agree with you.
However, at the super low end and most entry level I **might** make an exception with the A8-6600K (depending on sale prices of components including memory kits and discrete video cards)
For only $10 more (at regular price) than the Richland based Athlon x4 760K it gives the user 256 VLIW4 stream processors. At $89.99 the iGPU was free.
EDIT: A deal like this looks pretty decent to me also--> http://forums.anandtech.com/showthread.php?t=2393379 (In fact, I think it would probably make a good extreme budget build with this case---> http://forums.anandtech.com/showthread.php?t=2393220 and this PSU ---> http://forums.anandtech.com/showthread.php?t=2392689. $155 spent, and all a person would need is RAM and storage to finish off.)
With that mentioned, one disadvantage I see with using an APU in a budget gaming scenario is the need for dual channel memory kit (which is a variable cost adder dependent on whether fast or stock speed 2x 2Gb or 2 x 4GB kits are selected). Meanwhile budget cpu users with discrete video cards can get by with a single 4GB stick of value ram.
