budget system, please check parts
u7412369
without the power supply, comes upto be $730 (shipping included)
epox ultra nf4 $108
amd 3200+ Venice $163
XFX Geforce 6800GS PVT42GUAD7 $210
corsair value select 1GB $81
Western Digital Caviar SE 80GB $58
COOLER MASTER Centurion 5 $66
NEC Black IDE/ATAPI DVD Burner $44
any suggestions? i also need a power supply suggestion. thanks
if you are going to overclock that, the 3000+ would fair just as well as the 3200. the 3200 just has more flexible multiplier. seagate has 5year warranty but the wd still isnt a bad choice. the benq dw1640 would be the better choice of burners for the same price. for the psu, you cant go wrong with the fortron 450w for $50.
Go with the Sonata ll for form, fit and function. Also suggest you go with SATA HD to save IDE connections. If it were me I would opt for a Plextor IDE DVD burner. A few more bucks but way more reliable.
