Budget sound card: Crystal 4-Channel PCI $7.95 at CompGeeks
kbaxter
266
This is not a bad little card. I paid almost twice this for the one I used in my last budget system. It worked quite well and sounded great for the price.
Link to Card
More info:
* PCI Interface
* 64-bit Direct Sound Accelerator
* Line-In, Front Speaker-Out, Rear Speaker-Out, Mic-In, 15-pin Game/MIDI port
* Full Duplex Support
* Plug-n-Play
* Crystal CS4280 Chipset
* Two CD-Audio Connectors
* MP3, 4-Channel DVD Player Support
Includes: PCI Sound Card, Drivers CD
Kaieye
I bought about four of these sound cards from CompGeeks and you are correct in saying that they aren't half bad. But at my age, a crystal set probably sounds pretty good...
I recommend them for good basic sound.
kbaxter
266
Originally posted by: Visuvius
I could never get this card to work on my XP box :(
That's odd -- sorry to hear that.
I installed mine in a machine with XP Home. Worked great! Might have something to do with the chip set and/or CPU you're using. Or maybe the other PCI cards you have. My box didn't have any other PCI slots filled.....
RobCur
Banned
Oct 4, 2002
3,076
Good find and cheap too, i may get a few myself. The onboard sound blows btw, those thing slowing me down too much.
Mallow
6,108
If the mobo I'm using ever doesn't have builtin sound for a budget system I use this card :)
udonoogen
3,243
onboard sound slows computers down? i didn't know that ...
junked
7
They also seem to have this card for the same price.
The spec reads...
* CMI8738/PCI-SX HRTF Audio Com Chipset
* Supports C3DX Positional Audio in 4-channel speaker mode
* Direct Sound 3D and A3D Support
* Legacy Audio SB16 Compatible
* DLS Based wavetable music synthesizer
* Direct Music Support
* Drivers Support AC3 4.1 Channel Interface
* MPU-401 Port / Game Port Support
* 16 Bit Full Duplex Codec
* 4 Channel 16-bit DAC
* 32-bit PCI Bus Master Supported
Is this a better card ?
which one is better for my cheap linux system.
Danman
13,134
I bought several of these cards and had never had a problem with them. Very good basic cards for customers. :)
beyonddc
910
I just came back from MicroCenter, they're selling a MadDog brand's 4.1 channel soundcard for $9.99 after rebates. This might be a good deal for some people, because you can avoid paying shipping and handling at CompGeeks.
