I just said that I have never used amd, that's not to say I never use them. Actually I was set to buy the ryzen 5 1600af before it disappeared. What would you recommend in an amd cpu?
Well heck, you are being reasonable, and you posted back to your thread. That is practically unprecedented around here, when it is a new member.
😉 Pardon any undertone of salt in my previous post, and I will do my best to be of service now.
I would say wait and see how the new 10 series i3 line up compares with the Ryzen 3 3100 and 3300x. However, it does not look as though value conscious ITX mainboards will be launching with them. Unless that changes by the time the Ryzens hit next month, that is the way I'd go on a ITX budget system. Which is a weird phrase, since ITX brings a substantial premium over mATX, but as it has to fit on that shelf over the display you talked about, the cost difference is acceptable to you? mATX would save you quite a bit on the board, case would cost about the same. The 3300x is the best bang for buck, but if you can find the 3100 for MSRP of $99, it would still be worth the extra money to get the extra 4 threads, over a quad core lacking hyper threading/SMT. You can get some of the cost difference back by waiting for 2x8GB RGB 3200DDR to go on sale for around $65 again. That should happen before the new Ryzens hit. I buy the OLOy Warhawk and Team Nighthawk series for builds, when it is going for that price. Both have run their rated speeds, issue free, in the 3 and 4 series AM4 boards I have used them with. And maybe it is just me, but I would not spec a 3.5" HDD with an ITX build. sub $100 1TB SSD will be much faster, quieter, use less power, and produce less heat. I have seen a couple of brands in the $90 range from newegg the last couple of weeks.
But the best advice is wait; stock levels are terrible right now, and we are in transition to new hardware from both companies. It may help pricing on current stuff, and at the very least, stock levels on existing stuff should improve.
