FrietSauce
Hello,
I might be willing to build a PC for simple use, instead of simply buying a Mini PC.
The computer would be mostly used for mail, internet, a little bit of storage and Spider Solitaire (I know...). The computer will most likely run on Linux.
This is what I came up with:
Intel Celeron G1840 2.8GHz Dual-Core Processor - €39,80
MSI H81M-P33 Micro ATX LGA1150 Motherboard - €42,80
Corsair 4GB (1 x 4GB) DDR3-1333 Memory - €27,80
A-Data Premier Pro SP600 64GB 2.5" Solid State Drive - €28,90
Zalman ZM-T3 MicroATX Mini Tower Case - €37,00
EVGA 430W 80+ Certified ATX Power Supply - €37,00
Total - €221,30
PCPartPicker list: http://de.pcpartpicker.com/p/hPgcK8
I'm sure it isn't perfect, which is why I came here. Please let me know if you have any suggestions or improvements.
Please note that I live in the Netherlands, so not all components available in the US are available here. I used the German version of PCPartPicker because all components on there are available in the Netherlands, in my experience.
EDIT:
I missed some additional information, I just realized.
I will probably be buying from www.azerty.nl, because so far they have had almost every single product I needed at a good price.
I do not intend on using any parts I have laying around and I do not plan to overclock the build.
For budget PC's I do not have brand preference as long as it works and is affordable with the budget.
The budget would be €250.
The monitor resolution will be either 1360x768 or 1920x1080, the last one most likely.
I plan on building it the upcoming weeks.
Thanks in advance!
Total - €221,30
EDIT:
Thanks in advance!
