Budget cases, help me choose
ditto21
7
I'm looking at two right now that fall into my price range.
http://www.newegg.com/Product/Product.asp?item=N82E16811119106
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208022
I've had heating issues over the years (two graphics cards artifacting, and generally high temps), and I need a decently priced case with really good air flow. I'm looking at cases with 3 120mm's and side air ducts, especially because I don't have the tools/space to mod anything. I'm a little reluctant on the Coolermaster case because the front-intake fan doesn't really have a large enough hole in the front of the case to work with, but the price is really good. What do you guys think?
Zepper
18,998
SVC.com still has some Coolermaster Mystique 631 models left - this might be the last day to qualify for the rebate. Also look at my rosewill thread the 5600 series are some of the best cases you can get for under $100. The R6A series isn't half bad either but may be a bit tight for the longer vid cards.
.bh.
