I'm pretty out of the loop but am looking to build a budget rig for my dad's business. I've built before, but I dont really have time to research and poke around for low-end combos and such because I dont know what to bother with.
my biggest issue is which cpu/mobo combo to go with. Anyone have some advice or care to point me in the right direction?
Thanks
1. What YOUR PC will be used for: very minor photoshop work, light web browsing, email, running Roland Versaworks printer software (its not that heavy)
2. What YOUR budget is: ~$600, need Windows 7
3. What country: US
4. IF YOU have a brand preference: WD hard drives, all else is whatever
5. If YOU intend on using any of YOUR current parts: nope
6. IF YOU have searched and/or read similar threads: everything is well over mah budget
7. IF YOU plan on overclocking or run the system at default speeds: default, this is for a business and just needs to be stable.
8. What resolution YOU plan on gaming with: no gaming. using 2 19" monitors, require DUAL DVI out from the video.
9. WHEN do you plan to build it? in the next 2 weeks
Thanks
