BTX cases fit ATX mobo?
The_Lurker
1,366
Just did some thinking and looked at some BTX only cases.. realize now this is a stupid question. Seems the answer is no... damn
GalvanizedYankee
6,986
Using Newegg's search engine you will find cases that accept both ATX and BTX format.
My hope is that case suppliers will offer slide-out replacement trays in BTX format for future up-grade.
Galvanized
Zepper
18,998
Some of the Aerocool models start as an ATX and you can get a kit to convert to BTX. The Masstige is one of them and the Aeroengine I think.
.bh.
BlingBlingArsch
1,249
last time i thought about BTX was a year ago. Are there fine cases out there now, or will it take another year. Iam not angry that btx is coming slow since iam satisified with atx cases.
JEDIYoda
33,986
3,321
BTX in my opinion is a dead horse.
It was another grand scheme by Intel that AMD and others refused to accept!!
Thus its dead!!
imported_Kiwi
1,375
Intel started pushing the BTX idea when they were still hoping to get better results from Prescotts in the 4 GHz-upward range, where the cpu's are power-hungry and just plain red-hot with waste heat. AMD's A64's run so much cooler than the Prescotts that it'd be silly for AMD to suggest to its supporters that anything similar to BTX was needed.
Very few of the high-volume case manufacturers ever offered much in BTX, and the few that had anything, were starting with an ATX as base, and offering a way to mount a different tray for opposite-side access, at extra cost.
jlbenedict
Banned
Jul 10, 2005
3,724
BTX is dead.
There was a small statement in the latest issue of Maximum PC from an Intel representitive stating it was all but dead..
The_Lurker
1,366
Actually the only reason I want a BTX case is that it opens up on the right hand side, which is pefect for my desk arrangment. It's hard to find cases that open up on the right hand side for ATX.
