BSOD while playing game, think sound card is the problem
Leros
21,867
7
I was playing Guild Wars and about an hour into it, my computer BSODd. Upon rebooting I send in the error report and got back a link for for a fix. It says there is a problem with ctcms.exe
Link to Microsoft page, the creative link doesnt work with this forum's sytnax
Microsofts link page to Creative's fix page
I started following the instructions to the point where its says
Click Start, Run and type %USERPROFILE%\Application Data\Creative\Media Database then press OK.
However, this comes up saying that it cannot find that path. So I opened up MyComputer and sure enough there is no Media Database folder.
Apparently this fix isnt my problem. According to Event Viewer, the system kernel crashed.
Any ideas on what happened?
Leros
21,867
7
Originally posted by: ch33zw1z
Did you get the STOP error and x.sys file name listed in the BSOD?
Of course not. :D
When I reinstalled Windows, I forgot to uncheck the box to automaticaly restart when the system crashes.
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Of course not. :D
Look in the event viewer. The system should have written a stop error event to it just before restarting.
Leros
21,867
7
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 11/19/2006
Time: 2:32:38 AM
User: N/A
Computer: JUSTINSPC
Description:
Error code 100000d1, parameter1 00000000, parameter2 00000002, parameter3 00000000, parameter4 b0d54343.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 64 100000d
0020: 31 20 20 50 61 72 61 6d 1 Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 30 30 2c 20 000000,
0038: 30 30 30 30 30 30 30 32 00000002
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 62 30 64 35 00, b0d5
0050: 34 33 34 33 4343
