BSOD Problem
mattyqp
7
Okay, so I built a new machine, in fact I am typing on it right now. I am not overclocking.
Here's the problem:
Three times now I have BSODs with a PAge Fault
0x00000050 PAGE_FAULT_IN_NONPAGED_AREA
Here's the machine:
AMD 3800+
ASUS A8V
2 WD 200Gb SATA RAID 0
1 WD 160Gb
eVGA GeForce 6800GT
1MB Corsair Value Select RAM
Enermax Noisetaker 470W
Audigy 2 Platinum Pro
Antec SuperLAN boy Case
Windows XP SP1
I ran a RAM check for hours with Memtest 86 v.31 - NO problems
Is this a driver conflict?
I tried to look for an Error log, and I found it, but I can't open it.
What's going on?
kylef
1,430
When do the blue screens occur? During boot, or while you're logged in doing other things?
And does Online Crash Analysis tell you anything when you send the error report? (You can configure this with My Computer -> Properties -> Advanced -> Error Reporting).
PAGEFAULT_IN_NONPAGED_AREA stop codes are generally hard to diagnose. Drivers can cause them by overwriting the kernel's memory management data structures, but more often than not they represent hardware malfunctions.
I'd start trying the obvious: remove all unecessary devices. Relax memory timings, turn off dual channel mode, etc. Then add each of these back one by one until you start getting the instabilities again.
mattyqp
7
Thanks.
Before it was during login. This time I booted up and Windows told me that it recovered from a serious error.
I looked at the sysdata.xml, and I can't seem to find anything. I will just keep pluggin.
Here's the error code it gave me on boot up.
BCCode : 10000050 BCP1 : FEFFFFF8 BCP2 : 00000000 BCP3 : 8053C7B1
BCP4 : 00000000 OSVer : 5_1_2600 SP : 1_0 Product : 256_1
