well i had did manual memory timing as suggest by some forumers am running 11-12-11-29 now on manual without profile. i did a memtest on it overnight and happily to said i got 44 passes with 0 errors. i think this is stable right? after all i din get any bsod yet after 1 day of idle + usage so im still waiting if there is any error coming up.
btw one more question though. does those ram timing influence the cpu performance? i mean increasing or lowering the numbers.....does it affects the performance of everything..is higher better or lower??
It affects performance, but not like you're thinking. changing ram timings simply affects latency timings and so on. Not your cpu performance. But setting to recommended timings via other users with the same ram will almost always be recommended, as they've probably spent time researching and messing with their setup to get it " just right "
