Windows 98 List December 1998 Archives
                                 Re: INSTALL: MinSPs and stack overflow problems
                       Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
                       Next message: FA-Cup: "Re: APPs:Win98"
                       Previous message: Jimmy Hughes: "Re: APPs:IE4"
                       Next in thread: James Fadden: "Re: INSTALL: MinSPs and stack overflow problems"
                       Reply: James Fadden: "Re: INSTALL: MinSPs and stack overflow problems"
                  Protected mode has nothing to do with the bit length of the word. It's a CPU mode.
                  Many DOS programs run under DOS protected mode and still only uses 16-bit memory.
                  With QuickViewPlus from Inso you will get a right click options with .vxd files.
                  But if Gerard Thomas says that the vxd's run only in flat 32 bit memory space I guess they do. He knows
                  what he's talking about!
                  You can count me as convinced........ for the time being ;-)
                  Gerhard W
                  > In the case you bring up, of a VxD, Quickview is not designed to
                  >view a VxD file. That is why you will not see an entry for Quickview
                  >if you right-click on a VxD file. You can only get Quickview to view
                  >a VxD by renaming it to an exe file, i.e. by fooling it. But
                  >Quickview is not programmed to correctly interpret the LE signature
                  >and say that it is looking at a VxD. Instead it sees the MS-DOS
                  >signature "MZ" at the beginning of the file (which is something all
                  >Windows 95/98 programs have) and it views the file as if it were an
                  >MS-DOS executable. But this trick does not change the working code
                  >of the VxD which is still 32-bit code intended to run in protected
                  >mode under Windows 95/98.
Subject: STACK DUMP!!
                                        Original Message
                     Date: February 28, 1999 at 21:20:18
                     Comment:
                          My explorer keeps crashing and crashing and crashing. I
                          reformatted and reinstalled Win98 but the same thing
                          happens. It is a New amdk6 3D 2 400mhz with pc100
                          64 SD. it is very odd. also I am curious why my 10.6 gig
                          hd gets read in windows as 10 gig. do I lose 600 megs?
                          weirdness.... thanks in advance.
                          Bob
                                       Response Number 1
                     Date: March 01, 1999 at 00:14:49
                     Reply:
                          Virtual Cache
                          This is the Disk Cache (replacement for smartdrive), not
                          to confuse with Virtual Memory. Some users only use a
                          maximum setting, others a maximum and minimum setting.
                          Just experiment and find what's best in your situation.
                          Open System.ini for editing (click Start > Run and type
                          sysedit in the Open box and click OK)
                          Or use find type sysedit and create a shortcut for easy
                          access.
                          Select System.ini in the System Configuration Editor to
                          bring it to the front
                          Add these lines to the [vcache] section (add the section if
                          it's not there):
                          (I use this one with 64meg ram)
                          [vcache]
                          MinFileCache=4096
                          MaxFileCache=4096
                          or
                          [vcache]
                          MinFileCache=1024
                          MaxFileCache=8192
                          (This setting is for 32Mb RAM)
                          These values limit the size of the vcache (in kilobytes), so
                          that Windows is prevented from using more of your
                          available RAM for the vcache. This will increase the
                          amount of free memory available to your system, so that
                          when you open another program it is not paged to disk
                          immediately due to lack of free memory.
                          The MinFileCache (=Minimum File Cache) setting
                          prevents Windows 95 from shrinking the cache below
                          1024Kb. As a rule of thumb, use 25% of your RAM for
                          the MaxFileCache. In general, most users say that a
                          MaxFileCache (=Maximum File Cache setting) of up to
                          9Mb works best for them, even if they have more RAM
                          available. Just experiment with these settings to find what
                          works best for you. You can see how your vcache
                          behaves by starting System Monitor (Sysmon.exe) from
                          your Windows directory. Choose Edit > Add Item >
                          Memory Manager > Disk cache size.
