- Dec 3, 2002
- 3,763
- 0
- 0
Not a car thread for The Garage, but a thread about something I use for my car/bike!
Anyone have one of those little electric air compressors you use to inflate tires die on you? Mine was this one or very similar, not that old:
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
I should probably just toss it and buy a new one, but I was curious since it shows some signs of life when you flip the switch. I have an adapter so I can plug it into a wall socket to test it. I took it apart to see what was up. The little eletric motor lets out a continual whine when turned on, and spins just a very tiny bit when you flip the switch before stopping. There isn't something physical blocking the rotation, there's a little wheel on one end of the motor that you can freely grab and rotate around yourself fairly easily.
Anyone know what would cause a small electric motor to fail like this?
