BigfootsMonk
Hello,
Used to have a Jetway A210GDMS PRO but it sucked and it's broken. Just normal computing with no OC or anything like that. Sent back to Newegg and got a refund.
Anyways, this is the board I'm looking at to replace it.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131049
The specs for the rest of the machine:
Athlon 64 3000+ Socket 939, stock heat sink
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537
Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811144113
Hitachi 160g PATA HDD ATA not crazy fast
no link
Some generic memory, 1g, DDR400
no link (will post more detai later today when I get the chance to check)
Videocard (needed for dual display)
http://www.newegg.com/Product/Product.asp?Item=N82E16814125044
Will the motherboard be compatible with these specs? I haven't seen anything that wouldn't be yet. More importantly Micro ATX is Micro ATX right? So it is guaranteed to fit in the case?
And will the motherboard be able to use the ATI Radeon 3 view thing where you can setup 3 monitors?
Horace
Case
no link
Horace
