Brightness level on my monitor
scsi drv1
190
I just got a bigger crt monitor from a good buddy of mine for really cheap ($50) but that problem I am having with it is the level of brightness it displays. I have tried using the osd on the monitor itself to adjust the brightness level but that doenst help much considering its at the highest level it can go. I also am using a dvi converter to display images on my monitor so if anyone can present me with options or ideas as to how to fix this please do. I am trying to play the new doom 3 expansion pack and it isnt working cause I cant see a darn thing.
BillyBobJoel71
2,610
crts in general are not too bright, but usualy enough so that your problem doesn't exist. try other monitors to see if its your monitor not the radeon.
