*Bridgestone it is* Urgent tire question
EDiT
993
*UPDATE* Thanks guys. I'm going with the Brigdestones. I'll post my opinion later.
I blew a tire and need to replace all four within a few hours of now. Anyone out there have thoughts on the two that I found in stock for about the same price? These are 205-55-16 V rated tires. They're going on a 2002 WRX.
Yokohama A550-V V rated from Sears
Bridgestone RE-730 Z rated from Costco
Please do not suggest others, since I need them today and those two are the reasonable ones I found in town. Also, since I'm trading the car in in a few months, I don't want to spend more than I really need to.
TIA.
GoodRevrnd
6,801
581
I hated the Yokhohamas on my SUV, my friend has Yokohamas on his S2000 though and they're fine. That probably doesn't help you very much.
LAUST
8,957
I got some Yok H rated AVS's on my truck and I love em.
TechnoKid
5,575
I'd go with the bridgestones as well...IMO a better tire than the yokos, but they will both be about the same in terms of noise. Costco also has great prices and road hazard warranty.
