Originally posted by: Kaervak
Originally posted by: Lifer
warped rotors?
That would be my guess.
Brake vibrate during "Acceleration"???
Originally posted by: notfred
Warped rotors don't make the brakes vibrate, they make the steering wheel vibrate. If you're feeling the brakes pulsating, that's what ABS is.
Brakes kinda vibrate/pulsate under hard acceleration (braking).
less noticeable to non-existent during like braking.
brake pads were changed 15k miles ago.
warped rotors?
edit: whoops, i meant the hard breaking kind of acceleration.
I disagree. If the rotors are warped, the pulsing will be felt at the brake pedal:
1. Rotor pulses due to warpage
2. Pulsing transmitted, via brake fluid, thru brake lines
3. Pulsing felt back at head-end, i.e. the brake pedal.
And yes; I know exactly how an automotive braking system works. When you press the pedal, it pushes a rod forward, moving a piston inside the master cylinder. That moving piston compresses the fluid, activiating calipers/shoes.
You WILL feel pulsing at the pedal if your rotors are warped.
Brakes kinda vibrate/pulsate under hard acceleration (braking). less noticeable to non-existent during like braking. brake pads were changed 15k miles ago. warped rotors? edit: whoops, i meant the hard breaking kind of acceleration.
I didnt read the rest of teh thread but <STRONG>Your Car has ABS</STRONG>
how are you going to tell me what options my car have. you don't even know that when my car was built, ABS was not even invented yet.
so NO, it does not have ABS![]()
Maybe if you have manual brakes, which very few cars have now. I really doubt you would (and in my experience, never have) feel the pedal pulsate due to warped rotors on a car with power brakes.
