Hi,
I currently drive a 2000 Mazda Protege and for about 1.5-2 years I've had this problem when I press down on my brakes. When I am going slow (about <15mph) and I lightly press on the brakes to slow down there is this squeaky, grinding, "metal on metal" noise. When I press the brakes hard this problem does not occur.
I have tried to fix this problems numerous times to no avail. I've had a mechanic try to fix this problem and he has changed out all the components of my brakes over the years and still the problem exists. I talked to my buddy and he said his dad had a similar problem and that a mechanic told him "you must live with it, there is nothing that can be done".
Does anyone have any advice on how I could fix this problem? Do I need more information to diagnose the problem? Or am I just SOL?
Thanks.
Edit: Corrected spelling of "brakes".
Thanks.
