Brakes on an older Expedition - cost question
Status
Not open for further replies.
911paramedic
I have a '97 expedition that needs brakes, and that's going to include new/resurfaced rotors. My question is, how much should this cost me?
I just need a ballpark figure so I can figure out if the mechanic is trying to pay off some Christmas bills, or being straight with me.
Thanks.
Northern CA if that matters...Bay Area to be exact.
Thanks.
Go to dealer, price out parts, price out cost per hour, then compare to how much your mechanic is charging you.
What was the parts list? Was it just rotors and new pads?
You can get good rotors for the front for $31 each RAYBESTOS Professional Grade and good brake pads for $30-40 for a set. Use Semi-Met on that type of vehicle.
Yea its a bigger vehicle but when I had my shop I treated it like any other sealed bearing car/truck. The only price diff back in the day was for a better set of Semi-Met pads.
You SHOULD be able to get all that done for $300 range IMO. Thats if there is nothing else needed like brake hoses/lines etc...
Buy the parts from Rockauto.com and find a shop to put them on. It pretty easy job from what I can see.
Is your Expedition 4WD or 2WD......makes a big difference in the cost of the rotors. As Marlin mentioned, decent rotors for the 4WD version aren't very expensive.
For the 2WD version, though, the rotors will be a bit more expensive.....count on at least $50-$60 per rotor at a minimum.
The pads.....I'm more of a Wagner SevereDuty semi-metallic fan, myself.....them and Wagner's ThermoQuiets. Both will be around $40 for a set.
Great input, thanks. It is a 4WD version, for those that asked.
I've never purchased parts and had a mechanic install them for me before. Is that something you guys are suggesting?
I'll call the shop on Monday and ask if that's something they do, or will do for me.
If you're doing all 4 wheels, then I see around $300 in parts and $130 in labor.
In the rust belt where I live, the rotors will be hell to get off, the clearance between the outer edge of the hub and the inside edge of the rotor hat is very tight, a little rust and you have a nasty job. Beat on them with a hammer too hard and you will destroy the wheel bearings, same goes for heating them too hot. Then there is the issue of the caliper slide pins being rusted inside the caliper bracket, another very common problem on disc brakes that will take an additional amount of time to rectify...130.00 for putting brakes on all 4 wheels is a bit low.
depending on your mechanics labor rate, you could expect 80.00 to 130.00 per axle for labor, depending on how difficult the rotors are to get off. If you dont have severely rusted rotors then it will be easier.
figure high, but you also have to figure the parts mark-up if your mechanic supplies the parts. People bitch and whine about auto shops marking up parts...thats part of what pays their overhead, along with the labor.
do people really think that products you buy at retail stores are sold at cost? even the parts store marks up the parts when they sell them.
I have no problem installing a customers supplied parts. but I will not warranty their parts! I will also not warranty my labor if their parts fail! The mark up on parts also assures that I will eat the costs associated with the part failing, and the labor to do it again. Then I go for a labor claim against the supplier of the defective parts.
Now if the customer supplied part fails due to my faulty labor, I will rectify the problem 100% on my dime! The customer would pay nothing at all.
that being said, if your mechanic is 600.00 or under for brake rotors and pads on all 4 wheels with him supplying the parts....I would do it...that sounds reasonable to me. Our shop does these alot for 580-625 depending on how bad the rotors and caliper slides are seized..
$400 is my guess.
This. In a previous thread I was looking up prices of rotors and for a ford bronco (big ass vehicle) it was about $20 per rotor. The brakes themselves are about another $20. Tack on the "my mechanic is an asshole" fee to double that. Then throw in 2 hours of labor = $400.
A few years back I had to get an estimate for my Ford Tempo and the estimate was $300. It's the same labor cost as your expedition but your parts are slightly more expensive.
edit
There's obviously a range of price and quality. Cheap brakes might be $5 while really top of the line brakes are $50. High performance rotors with fancy patterns and holes in them will obviously cost more than low performance ones.
Status
