Hello, I've been having brake problems after getting the rear brakes replaced recently. The rotors were turned as well.
Here are some of the symptoms:
1. Loud grinding noises when coming to a stop very slowly. When the car is moving fast and the brakes are applied, the noise isn't there or it cannot be heard.
2. Sometimes there is a squeaking noise when brakes are applied.
3. These noises have only occurred after getting the rear brake job done.
After going back to the dealer to tell them the problems, they told me that they reexamined and brakes and didn't find much wrong. They did apply some more of the material that makes the noise go away. The car was taken for a drive with two techs sitting and they did hear the noise.
I was told that maybe replacing the rotors would fix this issue but they are not sure what is going on.
The car is a Mazda 3 sedan.
I would appreciate if anyone can offer some insight into this issue. I'm thinking of taking the car elsewhere to have it looked at but I've generally been happy with the service from this dealer up to now. Not sure.
Thanks.
Thanks.
