- Oct 3, 2004
- 5,761
- 12
- 81
Car: 2002 Nissan Sentra
Mileage: 100k
Upon changing the front pads/rotors, I noticed that the outside pad was showing nearly 3 times as much wear as the inside pad, on both sides of the car.
We had the car aligned about 3 weeks ago and it still pulled to the right. The mechanic said the reason for this was because one of the pads was touching the rotor.
Tire pressures are equal and there doesn't seem to be any uneven tire wear.
Now that I have changed the pads and rotors, the car still pulls to the right and I am concerned that the pads will still wear unevenly.
What could be the issue?
Mileage: 100k
