evergreen96
Does anyone know what are the differences between these (beside compostion) Brake Pads
ie Pro and cons
Non Ferrous
Ceramic
Semi-Metallic
Organic
my friends says to gets the "semi-metallic" one
Also how to u tell by looking at it, which type of brake pads you have (non-ferrous, ceramic, semi-metallic, organic)
Which pads do you recommend for a 97 Camry LE (stock) I4 for Front Pads? There so many to choose of? How do I know which pad to buy. the regular one (one list at the top of page) or the 9" x 1.57"
Front Pad from Kragen / PartAmerica
Front Pads from Napa
ie Pro and cons
Non Ferrous
Ceramic
Semi-Metallic
Organic
