Brake fluid - some thoughts and experiences
Torn Mind
Spent a while on Sunday changing the brake fluid on mom' Toyota Matrix. I had changed it out 3 or 4 years prior to Supertech from Toyota factory brake fluid of 8 or 9 years. Now, I swapped in some Castrol DOT4 that allegedly is designed for British cars with a vented brake system. That means that the fluid is designed accumulate moisture more slowly, allegedly
Observation 1 was that the Supertech came out as a vibrant opaque green. I spilled the liquid today transferring it to a Powerade bottle., so no pics available. I will say that it was much faster in changing color and thus degraded much worse compared to the OEM Toyota sauce, which was kind of dark but not really when I changed it out. So, I'd definitely not repeat with the Supertech ever again for any daily driver car; It, like many other aftermarket parts priced at the bottom of the barrel, is for resellers or someone who has no plans to keep using the car after three years. .
It's a matter of wait-and-see if the Castrol is the OEM equivalent or better, since it is priced as upper-grade aftermarket. Indeed, the price was $10.32 for a quart on Jul 31 but it has since shot up to 17.20 on Walmart
I was intending to do gravity bleeding because I had time. But, I learned a lesson no to take a shortcut. Opening up all 4 bleeders at the same time is an invitation to letting air into the system if the car is angled the wrong way. The car was leaning forward and thus air entered the rear lines. Had to rectify that with the two-person method and mom pushing the pedal.
Also, I had no hoses, so there was plenty of squirting and shooting involved.
To see how this Castrol does will probably need 3 years for an update, as that is when I expect the EBC pads I installed to wear out and require a swap, along with new rotors since the use of cheap semi-metallics prior murdered the rotor. The car will definitely eclipse 200k miles by then.
No horror stories of rusty bleeders for this car. Mom bought it new in MD, which uses salt but it isn't a severe salt.
Have you ever thought about spending the money on a vacuum or pressure bleeder?
If I had the money, I'd go for a Mityvac system for sure. But 250+ dollars can go a long way for other things, especially since the cycle of fluid changes is only every 3 or more years.
A lot of enthusiasts just use the Motive pressure bleeder which cost $50-75 depending on the model you get. I use mine dry. Just fill up the reservoir attach the Motive and pump it up. The kit comes with a magnetic graduated catch bottle as well. Since brake fluid can't use the fancy color dye anymore and you can't always tell when you hit new fluid.
Once of the first things I do on any first brake change is put on speed bleeders. Loosen them quarter turn, attach a hose to a container, and pump the brakes a few times until fresh, keeping an eye on the master cylinder to top it off. Occasionally I've gotten really creative and used two phones with a video call so I can watch the hose from inside the car.
I agree with you, spending a bunch of money on a vacuum bleeder when there are much more exciting tools isn't my forte.
The reverse bleeder is one of the best tools in my shop... paid under $50 for my Mityvac. Used it recently to do my Impreza when I swapped all four calipers.
Basically, you "push" the fluid up from the calipers to the master cylinder & reservoir... so the air bubbles are naturally drawn upward and out of the system. It stays pressurized too, which is helpful if you need to make some checks and/or adjustments while the system is bleeding. Does the same thing as the brake pedal in that regard.
Scotty Kilmer had a video describing such a tool. The Phoenix Injector.
