krnmastersgt
Never really strayed to this part of the forums but since I'm relatively unsure of who to ask I figured the AT forums would be a cool place to start.
The issue: The car (90 Honda Accord) was running relatively fine (it has some issues that I'm aware of but isn't reasonable to fix for the price) until yesterday when I noticed I had to apply 3-4 times the normal force/distance on the brakes to actually get the car to slow down at all. From what I can see (and what the guys at Jiffy Lube said when I was getting all my filters/oil changed) is that the brake fluid reservoir is basically empty.
After a bit of research I see that it might be dangerous for the overall brake system if I just pour in some new DOT3 fluid as if the system is already almost empty/is empty then the potential air pocket in the brake lines could lead to a fairly catastrophic brake failure (and apparently ABS systems are somewhat more sensitive to this). Not really keen on paying the $140 (quote) for a full brake bleeding and I lack any of the tools to do it myself.
Question is, do I just top-off the reservoir and hope for the best or do I need to go to and have the full system bled? (currently still using the car btw, and when braking seems to be making an almost metal-on-metal screeching sound though its made the sound before when there were no issues with the pads/calipers/fluid levels so 😵)
