I'd like to get some opinions on this issue. Yesterday, had some new pads put in and my rotors resurfaced. For background purposes, this is the first time I've had my rotors done on the Subie but is my third set of pads.
New pads are direct replacements from what I had before, Hawk HP+'s which I've not had any issues with previously.
Anyways, performance wise the brakes seem fine, however when coming to a complete stop there is a whirring sound coming from the brakes, akin to a belt sander spinning down from high RPM.
Checked my rotors today and there are some serious grooves in them, which I believe are the cause of the noise.
I've attached pics here:
Front drivers side 1
Front drivers side 2
Front drivers side 3
Front passenger side for comparison
What has caused these grooves? Is this possibly due to incorrect installation of the pads or the worst rotor resurfacing job in the history of mankind? I'm near 100% positive this major groove was not on the drivers side rotor before I had this work performed. As I said earlier, only real problem is the noise, but I'm starting to get the feeling these pads might be getting chewed up.
Groove is towards the outside on the drivers side rotor, in case it's hard to tell.
