I've got a...
1991 Miata
turbocharged
no idle air control
The symptoms...
excessive slop in the brake pedal before brakes engage
noticeable, but not excessive, pedal force required to slow/stop car hard
if i pump the brake pedal a few times in the 'sloppy' area of it's travel the engine idle speed increases
What I've done...
two new front calipers (unrelated)
full brake system flush, improved brake feel a little
What could be causing this...
Bad brake booster?
Blown check valve somewhere? (is there one?)
Something completely unrelated?
Looking for input.
1991 Miata
turbocharged
no idle air control
The symptoms...
What I've done...
Bad brake booster?
Looking for input.
