Brainteaser-3 switches and alight bulb
imhotepmp
1,418
There is a closed room with a light in it. Outside, there are 3 light switches. You can flick any of the switches any number of times. You can only open the door and go into the room once. You know that the light is initially off. How can you determine which light switch operates the light?
Rules(To make it a little more difficult)
-You can not leave the door open
-You can not see under the door to see if the light is on.
anyone?
imhotepmp
RSI
7,281
snow patrol, you go in the room and I'll stand out here. When the light comes on, bang on the wall! ;)
-RSI
xero
917
just flip each switch in the opposite position it's currently in.... say switch 1 is pointing down, you point it up...switch 2 is pointed up, you point it down...etc
you never said that couldn't be done.....you're bound turn it on then :)
Superwombat
606
Remove the faceplate, check which light switch has wires going to it... if all three have wires, use a voltmeter to determine which are passing voltage. If all three match, cut all of the wires, then the answer is "none of them"
DaveJ
Flip the first switch on, leave it on for 10 minutes. Turn it off. Flip the second switch on, go inside and see which light is on. As for the two that are off, the one with the hot bulb is the one you left on, so it's controlled by the first switch. Hence, the last switch controls the one that is cold.
Dave
damocles
Thats close Dave, but i think there is only one bulb. So you flip switch 1 and leave it on for 10 minutes and then turn it off. Then turn switch 2 on.
Enter the room; To Determine which switch controls the light, do the following.
If the bulb is on, it is switch 2. If the bulb is warm, it is switch 1. If it is cold, it is switch 3.
DaveJ
Damocles: Yeah, that's exactly what I meant... :) Gotta get more sleep...
Dave
