By "box," do you mean your computer? If I learned anything in Physics, it was that charge on a conductor, will go to the outside of the conductor. That's why the computer's case is made of metal. So as long as your mobo is properly installed in the case (and your case is made of some conducting material), you shouldn't have to worry too much about zapping your case (just don't zap any of the components directly).
