- May 28, 2007
- 3,999
- 63
- 91
I'm making a small circuit so I headed to Radioshack and got some parts. First switch was an illuminated rocker switch for automotive, 12V 30A rated. It turned out all its *guts* were stored in the head of the switch (in front of the threaded mount) which takes up too much room for the door to shut on my project. So i went back and got another illuminated switch, this one stores all the guts in the threaded part of the switch, leaving a near flat illuminated rocker switch out front, taking up only 1/8" space instead of 3/4" like the other. Problem is it says 100-250V, 125VAC @ 16A or 250VAC@10A. I'm putting on a 7A 12VDC load. Will this fail to make the light on the switch illuminate? And seeing as 7A 12VDC is less than 120VAC 16A, it shouldn't burn up the switch right? I really don't care about the switch, it's only $2.99. I'm more worried about burning up the expensive power supply I running this thing because the illuminator in the switch blows up with only 12VDC or something.
New switch
Old Switch
New switch
Old Switch
