Absolution75
- Dec 3, 2007
- 983
- 3
- 81
AR-15 can also shoot 5.56, which has the same dimensions of .223. While 5.56 has received criticism for stopping power on the battlefield, the standard civilian police officer does not need such a round.
5.56 and .223 are basically the same round. There are some case dimension differences, but they are basically the same thing. You can shoot .223 out of a 5.56 and its fine. The only real difference is the amount of pressure the chamber is subject to when the round is fired, .223 expects lower chamber pressures and its generally not safe to fire a 5.56 out of a .223 chamber. Its the same for .308 and 7.62x51 (except backwards, .308 is the higher pressure round).
I really don't see how giving them a high powered rifle is going to make much of a difference to anyone except someone in body armor. You get hit by a 9mm Glock17 and you're still in a life threatening situation. Getting hit by a 5.56 projectile instead of a 9mm projectile isn't going to make a lot of difference. Police shoot to kill, what difference does it make if its from a different caliber.
Also, 5.56/.223 can penetrate Level 2 body armor, but not Level 3. Idk about armor piercing bullets though, I kinda doubt police run those.
Finally, afaik fragible ammo or whatever is crap and I doubt they use it. It still goes through walls and people just fine.
