Soft-modded X, used exclusively for XBMC. Well I was renaming the .xbe file so it'd boot straight to XBMC and I must've made a file name error without noticing, because when I reboot I get an error screen and I can't get to any dash. As a result, I also can't FTP and fix the problem.
Since the BIOS has already been modified, is there a boot disk or something I can make to get back into the HD and fix the filename, or is it possible to pull out the HD and plug it into a PC and fix it that way?
I didn't mod it myself, had a friend do it, so I don't have the hardware necessary to boot to a USB key or anything. Thanks in advance for any help.
