Bored...going to push my CPU to the limit...
Manzelle
1,396
Right now I am at 1.925v and 2.366GHz (206x11.5)...I am willing to go to 2.15v and 216x12.5 (2.7GHz)...I idle right now at like 38C so I don't think this will be too much of a burden on the ol' XP 2500+
I may slap a fresh coat of AS5 on there first though...I let you know how the results turn out...with pics (if successful)...
Looking at my set up I think VDIMM @ 2.9v and VCORE @ 2.0-2.15v should do it...maybe I'll up the VDD to 1.8v as well...
Soulkeeper
6,732
155
that's way too much voltage imho
i've fryed a couple athlons with less volts than that
good luck with 2.7ghz
just make sure you get some benchmarks before it frys :)
MDE
13,199
Good luck, I'll start the memorial fund for a new CPU for you...
Manzelle
1,396
Well, I am at work right now so I won't be able to do this until like 9am EST...I've been itching to switch to the Mobile 2600+ anyway so if by chance this does kill my CPU at least it gives me an excuse to grab the new chip...
magratton
523
Course, you could always sell that Athlon 2500 for $30 and only have to spend $50 on the mobile....
Falloutboy
5,916
with most bartons I've found once you get over 1.8 you only can really hope for another 100-200 mhz. I was rock solid at 2.5 with mine at 1.85 on air and only made it to 2.6 at 2.1V (I didn't keep it here for long) on water
