Bootup Problem
robkas
152
Whenever i restart my computer and don't have the windowsXP disc in the cd/dvd drive it goes to the black and says "Missing NTLDR....press CTRL ALT DELETE to restart"
i just reformatted, but this has never happened before.
robkas
152
alright thanks , i'll look into it.
if i can't figure out how to fix it i'll just unistall my old harddrive i just put in because i knwo that will fix it
Feb 19, 2001
20,155
23
I don't believe that's correct... Sometimes Vista's bootloader fvcks up for me and then when I select XP, it will tell me NTLDR is missing... what the problem was, was that Vista simply didn't reference my XP partition properly, so I went into Vista and fixed up its pathetic bootloader so it referred to the right partition. Voila!
If you have NTLDR problems, probably your boot manager is really fvcked up. The link you showed is probably someone running unstable components (hence 1 stick, bios flash, etc etc)
robkas
152
Originally posted by: rudder
Is there even an OS on the drive?
i just installed xp on my sata drive and it boots up fine when the windows CD is in the drive, but when the windows CD isn't in the drive it gives me the NTLDR missing
and i'm posting on the forums off of this computer haha
KeithTalent
Administrator
Nov 30, 2005
50,231
118
Did you copy the NTLDR manually over to your drive? Sometimes the file becomes corrupted or does not get copied over correctly by the boot disc. Try the NTLDR fix I linked to in the thread I mentioned above, or do it manually yourself.
corkyg
Elite Member | Peripherals
27,370
239
This is a common fault, and is threaded at least once a month. Just Google NTLDR Missing and there are lots of solutions. Mainly, the MS KB will suggest that you often need to reset your BIOS after making HDD changes, etc.
Pakman
807
Wow, I have the same problem... Ever since I reinstalled Windows XP, my PC will give me the NTLDR missing error message. But if I have my Windows XP CD in the drive while the PC is booting, Windows boots up fine. I'm gonna try resetting my bios to see if that fixes anything.
Bozo Galora
7,271
Originally posted by: Pakman
Welp, resetting the bios seemed to have fixed the problem.
um, "restting the bios" is unclear to me, does that just mean discharging cmos?
Brian48
3,410
Typically, whenever I see this message of late, it's because Windows is trying to boot from the wrong partition. I'd check the boot.ini file to make sure that it doesn't think the CD drive is the correct drive to boot from.
