Booting off a usb flash drive is faster than hard drive?
JEDI
29,391
2,738
winxp sp3
i'm tired of reinstalling os everytime i upgrade my hard drive.
i thought abouit having a small boot drive and D: as my storage/programs.
is a 8gig flash usb2.0 drive faster than hard drive?
dbcooper1
594
Why don't you just use one of the many imaging programs instead? Takes just a few minutes and you're ready to go with the new drive.
corkyg
Elite Member | Peripherals
27,370
240
You can't install genuine Windows on an external bootable device. For that use a Linux distro.
Chiropteran
9,811
110
Lower sustained but should be faster at random access times. USB drives vary a lot depending on manufacturer and model, a fast one would probably be decently fast.
VirtualLarry
56,587
10,225
Debunked! :)
No, he was right. You can put the Win7 installer (install from) onto a USB flash drive, and boot off of it, to install Win7, but you cannot put an installed (install to) Win7 on a USB flash drive.
OTOH, you can install from a flash drive, but you cannot install TO a flash drive. At least not with any current flavor of Windows. Linux can do it, of course. (Linux seemingly can do everything that Windows can't.)
Spikesoldier
6,766
is a usb flash drive faster than a hdd? nope but a ssd is faster than a hdd and can be installed to.
corkyg
27,370
240
Debunked! :)
The operative word was ON, not FROM. See VirtualLarry's note. I stand on my statement.
Agree about the SSD, but that was not the question. What limits the flash device is the transfer rate of USB. SSD is an internal SATA device.
ElFenix
102,402
8,574
this. you can even download a gimpy version of acronis from seagate and wd's sites if you want something idiot proof.
sm625
8,172
137
Not only have I installed XP onto a thumb drive, but I also made it think its a fixed disk and enabled EWF. Boot time was right up there with a traditional 7200rpm HDD.
Zap
22,377
7
Why not just jump on an SSD deal? I've already seen 60GB SSDs around $40, and this morning's first Newegg Shellshocker was a 120GB SSD for $70 (after measly $10 rebate). And no that wasn't some old Vertex Plus crap, but a Vertex 3. Yup, arguably one of the fastest on the market, if not the most reliable. :p
mfenn
22,400
www.mfenn.com
I suppose you should probably provide a procedure or at least a link to one.
sm625
8,172
137
Here is a link you need to help do it:
http://www.getusb.info/usb-hack-turn-a-usb-stick-into-a-hard-drive-or-local-disk/
cfadisk.inf works for CF cards too! This is the hitachi microdrive driver. It is a unique beast because it was probably the first removable disk that was actually a HDD, so they made a driver to make it a fixed disk. We just hack that driver.
What I did was I first installed XP onto a HDD so I could update it and get it ready for deployment without dealing with the headaches of a slow drive. Then when the OS is ready and has all the stuff I need, I shrink the partition down to 3.8GB using Easeus partition master. Then I use acronis to make an image. Then I restore that image onto my 4GB CF or usb drive. Acronis seems to be able to restore an image to any drive as long as it is fixed. Hell it restored to my CF card before I even did the fixed disk trick.
ewf guide:
http://blog.granturing.com/2007/12/this-guide-is-based-off-my-original-ewf.html
To create a usb installation flash drive:
http://techrena.net/install-windows-xp-usb-disk-drive-pen-drive/
Cloning Windows XP installed on a USB flash drive to another USB flash drive:
http://www.overclockers.com/cloning...a-usb-flash-drive-to-another-usb-flash-drive/
Illustrated walk-through_ Creating a bootable USB flash drive for Windows XP:
http://www.techrepublic.com/article...otable-usb-flash-drive-for-windows-xp/6160062
Yes, I've tried all these things with success.
